Gaming build for iRacing
Gaming, specifically iRacing, online car racing sim.
<$1000 w/tax and shipping.
Bakersfield,CA. I plan on purchasing through Amazon and/or Newegg. No MC or Frys within 2 hours.
CPU, Motherboard, Power Supply, Case, HDD, RAM, Video Card, Optical Drive
Mouse, KB, Monitor, Speakers
6) Will you be overclocking?
No
7) 7) What is the max resolution of your monitor? What size is it?
1920 x 1080, 27" x3
This week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
USB 3.0, SATA 6 Gb/s
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, Windows 7 Home Premium 64-bit
I am looking to build a rig for a friend to get started in iRacing. He is looking to
run triple monitors at 5760x1080. Here is my preliminary build list, please critique. TIA
$186 - Intel Core i5 4430
$70 - Kingston HyperX Blu 8GB (1x8 GB Module) 1600MHz 240-pin DDR3 Non-ECC CL10 Desktop Memory KHX1600C10D3B1/8G
$81 - ASRock H87M Pro4 LGA 1150 Intel H87 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
$330 – Gigabyte GTX 770 GDDR5-2GB 2xDVI/HDMI/DP OC WINDFORCE 3X Graphics Card GV-N770OC-2GD
$87 – Seagate Barracuda 2 TB HDD SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST2000DM001
$60 – Corsair Carbide Series200R Compact ATX Case
$21 – Lite-On Super AllWrite 24X SATA DVD+/-RW Dual Layer Drive - Bulk - IHAS124-04 (Black)
$86 - SeaSonic G Series 550-Watt ATX12V/EPS12V SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply SSR-550RM
Total - $921 plus tax
Thanks, Mike
To drive 5760x1080, I would recommend going with the GTX 770 4GB at the least.
As for the case, I recommend spending the extra $10 for the improved Corsair 230T:
$70 - Corsair Graphite Series 230T Black w/ Window ATX Case
Sounds good, Dangman. I know iRacing is not that hard on the GPU, but the 4GB would give us some peace of mind. The 230T looks like a good upgrade also. Thank You.
