1) What will you be doing with this PC? gaming and web browsing
2) What's your budget? hope to keep it around $500 usd
3) Which country do you live in? usa, portland, or
4) What exact parts do you need for that budget? cpu, ram, mobo, video card, hdd, case, psu, os
5) If reusing any parts, what parts will you be reusing? keyboard, mouse, 22" lcd (1680x1050)
6) Will you be overclocking? no
7) What is the max resolution of your monitor? 22" lcd 1680x1050
8) When do you plan on building/buying the PC? soonish
9) What features do you need in a motherboard? Mini ITX, Micro ATX.
10) Do you already have a legit and reusable/transferable OS key/license? no
so i'm going to try to get my girlfriend to start gaming with me (to cut me some slack).
going to be playing tera with her. max res on the 22" monitor i'm handing down is 1680x1050, and would like to play at max settings or at least close to it, which shouldn't be too hard in this budget. also looking for a good mini itx/micro atx board because i want to use the fractal core 1000 case http://www.newegg.com/Product/Product.aspx?Item=N82E16811352009 because i love the looks.
cpu - i3 2120 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115077 $128
video card - would something like a 560ti be overkill?
mobo - is z68 necessary since not overclocking? not really up to date with different chipsets for the lga1155 package. remember micro or mini atx
hdd - not really up to date on mechanical tech. prefer performance over size. wish i could put a ssd in here for her, but that would cut too hard in to the budget.
case - Fractal Core 1000 http://www.newegg.com/Product/Product.aspx?Item=N82E16811352009 ($40)
ram - gskill ripjaw ddr3 1600 2x4gb http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314 ($47) overkill? ram is cheap so don't think getting crappy ram is worth it
psu - no idea here...want something that is affordable (not cheap). don't want to skimp on quality here.
os - win7 ($100)
any help is appreciated to get the old lady off my back!
os - win7 ($100)
