Gaming Build for Friend's Dad
Hey guys, I'm looking to build my friend's dad a computer and I just wanted to make sure everything I have so far is compatible and a good deal. He's looking to spend around $900 for a decent gaming system, nothing top of the line but good for most games.
ASUS P8Z68-V LE Z68 and Intel Core i5 Sandy Bridge bundle
http://ncix.com/products/?sku=63253
Ultra LSP650 power supply
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3276573&CatId=1483
VisionTek Radeon HD5770
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1126189
2x4g Corsair CMZ8GX3M2A1600C9B DDR3 RAM
http://www8.ncix.ca/products/?sku=59431&vpn=CMZ8GX3M2A1600C9B&manufacture=Corsair
He will still be getting a mouse and keyboard and monitor, but that's not too important. Any advice would be greatly appreciated, thanks!
Please answer the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can help you better.
Though that PSU isn't a good choice at all.
Sorry, I didn't see this first.
Gaming(Call of Duty, Mass Effect, maybe some MMO's), web browsing.
$800-$1000, Yes, but depends.
Canada
Fresh build: Motherboard, CPU, RAM, PSU, CD drive, Video Card, Monitor, Keyboard, Mouse, Hard drive,case.
Fresh Build
6) Will you be overclocking?
Doubtful
Not sure yet, was thinking 22".
As soon as possible
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
SATA 6Gb/s, crossfire would be nice, USB3.0, PCIe
No, but it will be 64-bit
Also forgot to mention that this was the hard drive I wanted as well, the Seagate Barracuda 1TB 7200RPM 64MB SATA 6Gbps.
Prelim build (no monitor, mouse or keyboard):
$190 - Intel Core i5 2400
$100 - Intel BOXDH67BLB3 Intel H67 mATX Motherboard
$54 - G.Skill Ripjaws Series F3-12800CL9D-8GBRL 2 x 4GB DDR3 1600 RAM Combo
$160 - Sapphire Radeon HD 6870 1GB PCI-E Video Card
$110 - Seagate 1TB 7200RPM SATA 6.0Gb/s Hard Drive
$20 - LG DVD Burner
$64 - Antec High Current Gamer Series HCG-520 520W PSU
$100 - Windows 7 Home Premium SP1 64bit OEM
Total: $798 shipped
Notes:
- Since you're not overclocking, that Asus mobo + CPU combo wasn't needed at all. Since you're only getting a 22" monitor whose resolution is usually 1680x1050, you won't need Crossfire at all unless your friend's dad is the type that wants 300 FPS+ in games.
- The HD 5770 is a bit anemic for gaming on a 22". You want to aim for the HD 6870 at the least. Though if you have left-over cash, up the GPU to the GTX 560 TI.
- If possible, have your friend's dad actually go to the nearest computer store to try out mouse and keyboards. Considering that these are the two items he's gonna be using to interact with the PC, he should use ones that are comfortable for him to use.
- Choose your own case. I recommend the following cases (Don't have time to get Canadian links):
$50 - NZXT Source 210 Elite Black ATX Case
$50 - NZXT Source 210 Elite White with Black Front Trim ATX Case
$70 - Lian Li Lancool PC-K58 ATX Case
$88 - Lian Li Lancool PC-K58W ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$91 - Corsair Carbide Series 300R ATX Case
$85 - Cooler Master CM690 II Advance ATX Case
$100 - Corsair Carbide Series 400R ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$118 - Corsair Carbide Series 500R ATX Case
$130 - Lian Li PC-9F ATX Case
$120 - Fractal Design Define R3 Arctic White ATX Case
$125 - Fractal Design Define R3 Black Pearl ATX Case
$120 - Fractal Design Define R3 Silver Arrow ATX Case
$120 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$130 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$130 - NZXT Phantom PHAN-002OR Black Finish w/Orange Trim Full Tower ATX Case
$140 - Antec P280 ATX Case
$140 - Antec Performance One Series P183 V3 ATX Case
$140 - Corsair Obsidian Series 550D ATX Case
$140 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$144 - Silverstone RV03B-WA ATX case
$160 - Corsair Graphite Series 600TM ATX Case
$160 - Silverstone RV02B-W ATX case
$166 - Corsair Special Edition White Graphite Series 600T ATX Case
$178 - Silverstone RV02B-EW ATX case
$170 - Corsair Obsidian Series 650D ATX Case
$230 - Silverstone FT02B ATX Case
$270 - Corsair Obsidian Series 800D CC800DW Full Tower ATX Case
