Gaming build for ~$1500
Blind Man
Web browsing and gaming only
$1750 Max, would like to stay around $1500 (USD to make it simple)
3) Where do you live?
Ontario, Canada, however going to Florida for 2 weeks and plan to purchase parts down there from newegg (-not near a microcenter)
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Mobo, CPU, Ram, HD, GPU, PSU, Case
X-Fi XtremeMusic soundcard, and possibly toying around with using my 8800gt as a phyx card.
6) Will you be overclocking?
Yes
Just ordered 3x Dell U2311H, will probably be using them in portrait mode (3240x1920) - not included in price of build
Within the next two weeks or so.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Good overclocking and SLI/Crossfire support
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
yes, Win 7 x64
I plan on making the whole PC last for ~4years, with a GPU upgrade in 2 years or so.
Games I plan on playing:
Lots of SC2! (I know SC2 doesnt support landscape eyefinity resolutions, but I have read it works fine for portrait? who knows.)
-Left 4 Dead 2
-DIRT2
-WoW
-Mass Effect 2
-Mirror's Edge
-Dead Space
-Maybe some batman: AA
-I will probably be doing a playthrough of Crysis/Crysis:warhead (and maybe metro 2033 if it goes on sale again), however I don't need or expect to play these at max settings.
Current build I have made up:
Mobo: GIGABYTE GA-X58A-UD3R
CPU: Intel Core i7-930
Ram: G.SKILL 6GB (3 x 2GB) DDR3 1600
HD: WD Caviar Black WD1002FAEX 1TB
Case: Was thinking the Antec Nine Hundred Two (my brother has it, seems decent), I can get it locally for $129.00, so I'd feel comfortable getting anything else that price or less. (note: not sure how much room we have in the car on the way back so it may have to be available at Infonec, NCIX, newegg.ca)
PSU: Corsair 850HX?
GPU: Not sure what to do here. If i add up the first 4 parts and leave ~250$ for case+psu, that leaves me with 500-750$ left over for GPU(s).
Things I have considered: single 5870, 5870CF(a bit too expensive), 5970, GTX460SLI, GTX470SLI.
Based on this review it appears that the 470's in SLI would be perfect (costing me about 600$).
Any thoughts on the build?
Thanks guys!
Get the CPU + mobo as part of this combo deal to save $16:
$485 - Intel Core i7-930 CPU + Gigabyte GA-X58A-UD3R X58 ATX Motherboard Combo
Don't get the Antec 900-2. Not worth the money at all. There are often other cases out there have have more room, equal or better cooling, and equal or better quality for a lesser or the equal price. Some recommendations (should be able to find most of these locally):
$70 - Cooler Master RC-590-KKN1-GP ATX Case
$80 - Cooler Master RC-690-KKN1-GP ATX Case
$70 - Cooler Master CM690 II ATX Case
$90 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$100 - Lian Li Lancool PC-K7B ATX Case
$90 - Cooler Master HAF 922M RC-922M-KKN1-GP ATX Case
$110 - Lian Li PC-E8B ATX Case
$110 - Lian Li PC-7FN ATX Case
$120 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
Forget the 850HX and go with this higher quality PSU instead:
$150 - XFX XPS-850W-BES 850W Modular PSU
GPU wise, yeah the GTX 470 SLI route might be your best bet.
Thanks a lot for the suggestions (especially the list of cases). I think for the case I am going to go with the CM690 II Advanced, as i found a combo with the ram for 20$ off. Will also go with the power supply you recommended.
