Hi all, finally ready to pull the trigger unless someone tells me I'm crazy somewhere.
Mainly gaming, browsing, watching some videos.
<$1250 (Less is better
Ontario, Canada
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word
CPU, GPU, motherboard, RAM, case, SSD, HD, cooling.
Wifi card, cooling fans, mouse/keyboard.
6) Will you be overclocking?
Yes
2560x1440 27" (Will be overclocking to 120hz depending on the frame rates I can manage)
Buying tonight/tomorrow.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
SLI support, SATA 6Gb/s. Don't know if I need USB 3.0 to be honest.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Yes, 64bit.
Here's what I've come up with so far and am about to order the rest imminently:
CPU: Core i5-2550K - $173.00 (Already purchased)
GPU: Gigabyte GeForce GTX 670 OC 2GB - $425
Mobo: ASRock Fatal1ty Z77 - $160 (Already purchased)
RAM: Corsair Vengeance 8GB DDR3 1600MHz - $40
SSD: Crucial M4 128 GB - $120
Case:
HD: Seagate 2TB Barracuda 7200rpm SATA III - $110
Cooling: Corsair H100 - $100
PSU: NXZT Hale 82 750W - $50 (Already purchased)
I've spent about $385 already for a CPU, mobo and PSU. $400-$425 for GPU, $230 on storage, and $140 on cooling/ram leaves me with ~$100 for a case. I'm also grabbing a sound card but left it out of this budget.
I have seen Danny Bui's case list several times, but I struggle to find something in my price range that can fit an H100 consistently in a push/pull configuration. I've checked the Corsair forums and OCN but people seem to get different results depending on motherboard size and layout. Any suggestions? I struggle justifying spending much more than $125 on a case but could be swayed either way.
Ontario, Canada
Yes
Case:
