Gaming mostly. WoW, Black Ops, TF2. Haven't really ventured into too many newer games because my current computer struggles at 2560x1600 in them.
Around $2000 is what im looking to spend.
3) Where do you live?
Stationed in Germany. APO shipping will make ordering a bit more difficult. I will have to use Amazon for as much stuff as I can but some things they wont ship overseas. So I probably use Newegg and pay the high shipping prices.
Case, PSU, Ram, Mobo, CPU, Video card(s), Blu ray player(light htpc use), and a good heatsink for OC'ing.
Nothing this is a total rebuild.
6) Will you be overclocking?
Yes Sandy Bridge seems promising for OC'ing so im looking forward to that.
I have a dell 3007wfp so any suggestions for what video cards to use for 2560 is welcomed.
After Sandy Bridge is released.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Xfire/SLI support, usb 3.0, and sata 6gb.
Yes, Win 7 Pro. It is 64bit.
First let me restate that I am stationed at Ramstein AB, Germany. Because of that I dont necessarily get to look for the best deals. At the moment it seems that because Amazon offers free shipping that they are by far the cheapest place to buy my parts. However certain items they will not send to APO addresses. For those I will probably use Newegg but if any of you know of a site that is good with APO addresses please let me know.
Parts I am thinking of at the moment. I have not included CPU or Motherboard because Sandy Bridge is not yet released. I am probably going to get a Gigabyte UD4 and a 2600k i7 but suggestions here are definitely welcomed.
$74.99 Corsair Cooling Hydro Series H50 All in One High-performance CPU Cooler CWCH50-1 http://www.amazon.com/gp/product/B002QG2H7K/ref=ord_cart_shr?ie=UTF8&m=ATVPDKIKX0DER
Im not sure if I should just get a big heatsink like the Cooler master 212 or if something like the H50 would be better coupled with the Raven case. Also if I do go with the h50 should it mount fine on the new sandy bridge mobo's?
$178.00 SilverStone 0.8 mm Steel SSI CEB / ATX Full Tower Computer Case with Side Window RV02B-EW http://www.amazon.com/gp/product/B004BDOGSO/ref=ord_cart_shr?ie=UTF8&m=ATVPDKIKX0DER
Kyles build article pretty much sold me on this case and I am definitly looking forward to see how much better air cooling is with this design.
$379.99 x2 Sapphire Radeon HD 6970 2 GB http://www.amazon.com/gp/product/B004FPYJF8/ref=ord_cart_shr?ie=UTF8&m=ATVPDKIKX0DER
I am tempted to go with the best of the best and get two 580's instead but for the price the performance gain doesn't seem entirely worth it to me, suggestions?
$219.99 Corsair CMPSU-1000HX 1000-Watt HX Professional Series http://www.amazon.com/gp/product/B00154QAXQ/ref=ord_cart_shr?ie=UTF8&m=ATVPDKIKX0DER
I think I remember reading that these PSU's dont play well with the Silverstone cases because of how the fan meets the case opening but I cant remember for sure. Is this PSU overkill for this setup? I wont be running large HD setups or much else on the computer itself this is mainly for gaming not much else.
$74.99 Samsung 12x Blu ray/combo drive http://www.newegg.com/Product/Product.aspx?Item=N82E16827151222
Went with it because its 12x and not much other reason, good choice?
$229.99 OCZ Vertex 2 SSD http://www.newegg.com/Product/Product.aspx?Item=N82E16820227551
Not sure about this entirely. Will loading times be much different compared to maybe a Raid 0 setup with some larger WD black caviars?
$159.99 G Skill Ripjaws 8gb (2 x 4gb) DDR3 1600 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231401
I'll be honest I've been lazy here and havent researched Sandy bridge too much I believe their motherboards use Dual channel, am I correct there? How about the RAM does it seem like a good choice?
$34.99 Scythe KM01-BK "KAZE MASTER" 5.25" Bay Fan Controller http://www.newegg.com/Product/Product.aspx?Item=N82E16811998038
I like a quiet computer sometimes and good cooling other times so I am looking at this, but really with the Raven case do you guys think I'll need it since fan speed switches are built in?
I am estimating the cost of a 2600k Sandy CPU at about $300 + $250 for mobo. Does that sound about accurate?
Total without CPU/Mobo is $1732.92 + $18.34 for Neweggs terribly expensive APO shipping.
Thank you guys for any help.
