- Oct 11, 2003
1) What will you be doing with this PC?
Gaming: Crysis, STALKER, SC2, Diablo 3, Elder Scrolls VI
$500, tax & shipping excluded
3) Where do you live?
WA State
4) What exact parts do you need for that budget?
CPU, Mobo, HDD, PSU, Case(see below), Ram, Video Card, CD Burner
I could use this old case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129120
6) Will you be overclocking?
Nope
24" 16:10
ASAP
9) What features do you need in a motherboard?
Nothing really needed. SLI / Crossfire would be handy for upgrading in the future, but I reckon my budget limits me here
10) Do you already have a legit and reusable/transferable OS key/license?
Yes -- Win 7 Ult 64bit
Not sure if it is worth noting, but my roommates requested that when i order my PC, that i get one for them too. The only difference might be the case (though maybe not, if i cant re-use that case... i'll need your input for this)
