Gaming Build ~1k
Cruel
Gaming, Browsing
~1,000~ all together
3) Where do you live?
Seattle, WA
CPU, RAM, Case, PSU, SSD, HD, MB, Optical drive ( DVD rw + CD rw blu ray a plus but not needed ), Windows 7 64 bit
Monitor
6) Will you be overclocking?
Nah
23" have
Placing the order before years end.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
SLI/Xfire support would be nice for future expansions. USB 3.0 a plus.
No.
There it is guys, looking to upgrade finally after 6 years of the same rig. I want something that will stand the test of time and not force me to upgrade for another 5 if possible. Thanks guys.
$273 - AMD Phenom II X4 955 Black Edition CPU + Asus M4A89GTD PRO/USB3 AMD 890GX ATX Motherboard Combo
$43 - G.Skill F3-10600CL9D-4GBNT 2 x 2GB DDR3 1333 RAM
$300 - Asus EAH6950/2DI2S/2GD5 Radeon HD 6950 1GB PCI-E Video Card
$55 - Samsung Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s Hard Drive
$18 - Samsung SH-S222L SATA DVD Burner
$80 - Antec Truepower New TP-650 650W PSU
$100 - Windows 7 Home Premium 64bit OEM
Total: $869 plus tax and shipping
I could not fit in a Blu-ray or SSD. But the above setup should be pretty solid.
Choose your own case. I recommend the following:
$60 - Cooler Master HAF 912 RC-912-KKN1 ATX Case
$80 - Cooler Master RC-590-KKN1-GP ATX Case
$80 - Cooler Master CM690 II Basic ATX Case
$80 - Lian Li Lancool PC-K58 ATX Case
$90 - Lian Li Lancool PC-K56 ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$100 - Lian Li PC-60FN ATX Case
$110 - Lian Li PC-7B Plus II ATX Case
$100 - Lian Li Lancool PC-K7B ATX Case
$120 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$110 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
