Gaming build, 1000-1200~ $
Sage2k
Need help with a new gaming build. Current PC is almost 5 years old.
Gaming, and web browsing.
somewhat flexible. I want value for my $. So between 1000 - 1200$ is acceptable
US, Baton Rouge, LA
Case, Modular PSU, Mobo, CPU, RAM (16gb at least), CPU cooler, Video card, DVD Burner, any extras like additional fans if necessary
I will reuse a 128gb SSD, and 4 3.5 hdd's.
6) Will you be overclocking?
I would like to do moderate overclocking. Nothing hardcore. Most likely I'd keep it stock until new games got slow then I'd overclock to keep up. So I want a somewhat decent heatsink
Currently have dual 22 inch, will most likely buy a 24 inch soon. I only game on one monitor. Don't include 24 inch monitor in quote.
Hopefully soon.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3.0 and Sata 6gb for sure. RAID would be nice but not required.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I get a free legal copy of windows 7 64bit from work
I don't know if i should build now, or wait till around November. I can stand to wait because the games I really want to play are Skyrim and Diablo 3, and they arent released yet. Currently newegg has a sale on Corsair HX850 modular PSU and Antec DF-85 so I might just buy those and wait till November, but if there are enough deals I might just piece together the whole computer now and purchase. I know for sure I want an i7 2600k, 16gb of ram, and a modular PSU. I'm unsure of what good mobo , heatsink, and video card to get. A large case is a must because I want more hard drives in the future, so the Antec DF-85 is attractive to me. Any opinions?
lose the Vista free or not its going to bog any high end pc down even with sp2 installed and 8 gigs of ram spend 100 bucks and get win 7 home prem 64 bit fron newegg.com.
If you can stand to wait then wait. Bulldozer and HD7000 are close enough that it's worth hanging on for a little bit to see what's going to happen. I wouldn't bother buying the PSU and case now unless the deal is huge (like 25%+ off)
Yeah I say wait as well.
Though I would avoid that Antec case since it's basically cramped as hell once you actually start using all those HDD bays. Plus its quality is not as good as other $150 to $170 cases out there. I'd only recommend getting that case if it was like $100 to $120.
I recommend this case instead:
$130 - Fractal Design Define R3 Black ATX Case
Fits 8 hard drives and won't be that cramped once you start using the HDD bays,
