âVelocitymasterâ
- Dec 12, 2004
setup as follows...
QX6700 OC 3.2ghz FSB 320X10 Zalman9700 Volts 1.55 set in BIOS
Mobo Evga 680i SLI A1 with new BIOS P30
Ram 2 gigs Corsair Dominator 1066 OC to 1120mhz 2.2volts "manufacture voltage" with stock timing set in the BIOS.
2 Evga 8800GTX SLI drivers 158.22
Creative X-fi gamer
Enermax 850W PSU
Win XP 32bit
other config
FSB 1.4v
HT(SPP-MCP) 1.2v "auto"
nfoce SPP 1.5
Nfoce at 1.5v auto
all this ran stable for 2 months.
my OC is done only in the BIOS
I disable all what needs to be disable in the BIOS before overclocking on the 680i mobo oc guide and same applies to the C2d OC guide.
The computer was built 2 half months ago and run very stable on all games. I ran Orthos for about 9 hours in this OC settings with no lockups very stable, screen capture here http://img382.imageshack.us/my.php?image=stresstestcc9.jpg I did also ran memtest for 10 hours with the OC setting and got no errors. But that was before this situation.
Since last week I was playing Call of Duty 2 find then it lockup, only way was to hit reset to reboot, I try all other games like far cry, serious sam II, Stalker and BF2142 they will freeze, after I reboot and reboot, I try any of this games they will hang or freeze. It can be any where from few secs in the game or 4 min even 10 min in.... I turn my computer off for 10 min or so "unplug it" then it will run fine in a game for 2-3 hours fine, then the next day I came back from work ran a game boom there it goes again.
Before this all happen since I had my machine up and running, games would ran for hours with any problems.
First I thought might be my software, reinstall the video drivers current and the new beta one, reinstall windows, try 1 video card then the other but still the same problem. I figure it out that was not any of my video cards, I also try my onboard sound for a while then this problem happen again. The computer runs fine when encoding videos and nothing happen when not gaming.
What I did was set the nfoce spp to 1.5v and move up the CPU volt to 1.6v ran for 2 days smooth and this it lockup again. I notice after changing my OC values then it runs fine for a day or 2. Now im very worry. At this moment I back out of overclocking first time and running my CPU ram and voltage at default speed. For sure this is not a software or driver issue. Hopefully this problem wont come back or I will have to RMA my mobo
I have to run this default hardware setting for 2-3 days just to be sure is not overclocking related
Anyone heard of this problem?
Creative X-fi gamer
Enermax 850W PSU
Win XP 32bit
other config
FSB 1.4v
nfoce SPP 1.5
Nfoce at 1.5v auto
