Negative Decibel
- Dec 13, 2005
I just landed a new client with an awesome budget... I wanted to see what y'all could come up with...
Straight up gaming rig1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc
$2700 max, including shipping2) What's your budget? Are tax and shipping included?
Aiken, SC 298013) Which country do you live in? If the U.S, please tell us the state and city if possible.
Literally everything; cpu, hsf, mobo, ram, psu, gpu(s), harddrive(s), case, os, keyboard, mouse, lcd,4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need.
nothing; completely scratch5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model.
Probably a moderate; yet stable oc6) Will you be overclocking?
need to buy... I'm thinking a 27 or 30" lcd7) What is the max resolution of your monitor? What size is it?
about a week8) When do you plan on building/buying the PC?
Obviously with this budget, I see doing Crossfire or SLI... other than that; no other special features needed.9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
not yet; need. probably windows 7 home premium 64bit.10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit?
