I'm hoping for help putting together a new system, it has been years since I last kept up with this... Grateful for any help!
Gaming CoH2, Orcs must die1/2/unchained, new Total Warhammer looks interesting, web browsing, school work, email
$2,000/yes
USA, Pensacola, FL
Case, motherboard, videocard, memory, CPU, CPU-cooler, PSU, dvd-burner, keyboard (wired), mouse (wired), 500 G SSD (OS+games), 4 TB-ish HDD storage, monitor (~27"), thermal compound, some reasonable 2.1 computer speakers, and anything else I missed.
None
6) Will you be overclocking?
No
Current monitor 1920x1080, HP2711, pretty happy with it, but it will stay with old system, so something similar, maybe slightly better
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0, SATA 6Gb/s eSATA
Yes, Win7 64
$2,000/yes
USA, Pensacola, FL
None
No
Now
Yes, Win7 64
