Sep 28, 2007 #1 K kc7hif Weaksauce Joined Dec 14, 2004 Messages 79 I have an antec 900 case, hooked the front audio ports to the mobo but they dont seem to be active, do I have to turn it on somewhere in the bios?
Sep 29, 2007 #2 kirbyrj Fully [H] 2FA Joined Feb 1, 2005 Messages 31,350 Check and see if you're hooking up the AC97 or the HD Audio pins. I think you'd want the HD Audio pins with that motherboard.
Oct 2, 2007 #3 K kc7hif Weaksauce Joined Dec 14, 2004 Messages 79 Fix was in mobo book, had to disable a checkbox within the audio software.
