GA-P35-DS3P default voltages?
Technophobe
On this motherboard, does anyone know what the default voltages are for:
PCI-E
FSB
(G)MCH
There are custom voltage controls in BIOS for each of these but nowhere can I find (via manual, BIOS, utilities or web browsing) what they are by default. Does anyone know?
I've logged a question to Gigabyte support but they usually take forever to reply (and then its usually a very vague answer).
.P35 MCH datasheet:
Power and Grounds
Name Voltage Description
VCC 1.25 V Core Power <----------- default MCH voltage
VTT 1.05V/1.2 V Processor System Bus Power <----------- default FSB voltage
VCC_EXP 1.25 V PCI Express* and DMI Power <----------- default PCI-e voltage
VCC_DDR 1.8V/1.5V DDR2/DDR3 System Memory Power <----------- default memory voltage
VCC_CKDDR 1.8V/1.5V DDR2/DDR3 System Clock Memory Power
VCC3_3 3.3 V 3.3 V CMOS Power
VCCAPLL_EXP 1.25 V PCI Express PLL Analog Power
VCCA_DPLLA 1.25 V Display PLL A Analog Power.
VCCA_DPLLB 1.25 V Display PLL B Analog Power.
VCCA_HPLL 1.25 V Host PLL Analog Power
VCCA_MPL 1.25 V System Memory PLL Analog Power
VCCA_DAC 3.3 V Display DAC Analog Power
VCCD_CRT 1.5/1.8 V Display Digital Supply Power
VCCDQ_CRT 1.5/1.8V CRTDAC Power
VCC_CL 1.25 V Controller Link Aux Power
VSS 0 V Ground
The FSB voltage is a bit trickier, per Intel specs:
GTL+ Gunning Transceiver Logic signaling technology. Implements a voltage level as
defined by VTT of 1.2 V.
and you need to read this to understand what is really going on,
http://www.thetechrepository.com/showthread.php?t=87
and so who knows what the manuf has done, Typically you dont want to mess with this unless as a last resort, it causes more harm than good and you probally would only then want to increase it one bump in value.
Technicls specs for Intel chipsets are found, wait for it, wait... wait...
on Intel.com.
Nice find...Kinda
How come when you add to either the fsb/mch or the pci everest still only reports those same voltages in the respective sections? I always assumed they were just reading the defaults, is this true and it does not make a real reading off anything?
I honestly have no idea, that would be a great question for a forum on the Everest web site. I would guess a lot of it is because there are many monitoring chips used by board manufactures and differenty ways of implementing them and the sofware cannot deal with all of them.
Yeah that is what I thought, I have put in to gigabyte at a forum I mod with them for gigabyet support to add in the values in the BIOS, who knows maybe they soon will but I kinda doubt it.
