CaptRingold
- Feb 12, 2005
I got together this new system a couple days ago, and after much tinkering, I seem to have some bum RAM.
Relevant parts:
E6600
4x2 1GB SuperTalent 4-4-3-8 (though I've loosend it to 5-5-5-15 till stability is established) @DDR800
Rev 2.2 with F10 BIOS
Watercooled, Corsair Nautilus 500 (side note: loud pump!)
I first tried to jump right in with the OC I wanted, 9x400, and thought I'd try to creep up the voltage to make it stable. I eventually realized that was going to be impossible.
Based on how Orthos works, it actually seems like the CPU itself is stable here, so then I went to Memtest86+ v2.7.
I lowered it to 6x400 to simulate stock CPU frequency but the higher FSB, and had the RAM 1:1 so it shouldn't of been OC'd. Memtest bled errors before freezing.
I play with voltages, +.1, +.2, +.3, +.4, +.5, some of which make Memtest bleed less, but never close to stable. I take the FSB back to stock 266 with the proper divider to get back to DDR800, same result. I try to underclock it, same result. I try +.1 to +.3v on the FSB and MCH, all to no avail.
I've got the C1E and whatnot disabled, but thats the only other major change. I tried all sorts of vcores up to 1.6 before realizing the CPU was happy as a lark and the errors were getting thrown by RAM.
Is there a problem having all 4 DIMM's populated in this board, or am I missing something? Or is my next recourse to try each individual pair of sticks to see if one pair is stable and the other not?
Edit: I know there's a similar thread going, but with a different problem I didn't want to hijack it with my own issues.
Relevant parts:
E6600
