FX-57 Vs Intell C2D
I am looking a building a game specific computer that will be running a single core supported game with no future dual core support for it. Would a FX-57 knowing that its the fastest processor for single core games be faster than one core of a C2D.
With the current speed that my E6300 is running at, it would smack around an FX-62 like an unwanted step-child. :D
No, the C2D's are very fast and really run rings around the fastest Athlon 64 chips currently. But, I just picked up one of the last OEM San Diego FX55's from The Egg for $130 and quickly OC'ed it to ~2.8 with my current setup! I will try for more Mhz tonight. In the mean time, I put my X2 4800 into my Linux server until I see games take advantage of the dual core chips (upon which time I will put back in the X2 4800 or hopefully by then ...have a C2D!)
$130 was a much better option for me than $700 for 2GB DDR2 memory, C2D 6600, and the DFI Infinity 975X board that I would indeed like to buy...someday...
Indeed, $130 is quite reasonable but in no way is it anywhere near the C2D in raw performance. But for the price its a reasonable upgrade and should run quite well in your gaming rig.
Hmm... so even if windows Xp doesnt support dual core processors on a single socket leading to timing issues it would still be faster than a FX Single core chipset running a game thats only design to use one core ? Ive seen benchmarks were the FX-57 was faster in FPS on single core games againts FX-62 and the other 4800.
Windows XP does support dual core. Besides, why would you specifically want single core and single core games? If next gen gaming is optimized for dual core, why not take advantage?
The only reason not to get a c2d over a fx57 is that you dont have the money for the upgrade to C2D.
All of the benchmarks i find all favor either the C2D or the fx 62 over the fx 57, with the C2D leading almost all the tests.
