FX-55 temperature question
Islelight
When I look at the temperature in the BIOS of my CPU it reads 54 C. Is this high for the FX-55. Im using a Thermaltake CL-0006 PIPE 101 with a UFO fan. THANKS!
cg rev. clawhammers don't report temps right.. but that is a little high.
did you apply your thermal paste like this?
I did apply the Thermaltake paste that came with the heat sink. My motherboard is an MSI K8N NEO 4 PLATINUM non SLI.
Did you spread it around or just put a blob in the middle?
Islelight said:
I spread it around.
You're not supposed to do that, air bubbles get trapped when you do that. Reapply it with a blob in the middle and let the heatsink distribute it.
