rolo said:Hah, so it seems like the options are either ... cross your fingers and get 2.9ghz on air, or spend lots of cash on water cooling for the ability to hit 3 to 3.5ghz easily. Sound about right?![]()
rolo said:No, I don't have an FX-55 (see sig)I was thinking about getting one, but I'd really like it to run at 3.0ghz. Otherwise it's much harder to justify spending all that cash.
{NcsO}ReichstaG said:You probably wouldn't hit 3.5 Ghz on water. You would need a "refrigerator" style cooler, a Vapo Phase or w/e its called. But anyway, you have a FX-55, why do you need to OC it? Its fast enough to handle ALLx1000000000 your needs. Your not going to be able to open Microsoft Office any faster you know![]()
James Earl Ray said:I run 3ghz 24/7 on water. It is quite common with the FX-55.![]()
2.9 Ghz on air is easy with multi10x290 if your memory can eat it or multi14.5x200. Just make sure your psu can supply enough juicerolo said:Hah, so it seems like the options are either ... cross your fingers and get 2.9ghz on air, or spend lots of cash on water cooling for the ability to hit 3 to 3.5ghz easily. Sound about right?![]()
joecuddles said:You won't hit 3 Ghz on water. You need phasechange ($1000+).
Captin Insano said:They can hit a little over 3ghz on water and real close to 4ghz with phasechange.
look at this link
http://www.hardforum.com/showthread.php?t=834807
Cpt
James Earl Ray said:Hey thats me!![]()
ZMTToxics said:Your an intel freak aren't you? Athlon chips (k7 / k8) are not about clock speeds. They are about doing more for every clock. For example, if have an fx55 at 2.6 doing 78billion instructions per-clock versus a Xeon at 3ghz doing only 31billion instructions per-clock, the difference will be very extreme, would it not? Speed is not always about the clock on your cpu.
James Earl Ray said:Sure, no problem. Just PM me when you have any questions.Oh I got a new gig of the Gskill and at the same speeds as the OCZ I get much better bandwidth. So you never know what you are gonna get.
I know the differences between the processors, thankyouverymuch.ZMTToxics said:Your an intel freak aren't you? Athlon chips (k7 / k8) are not about clock speeds. They are about doing more for every clock. For example, if have an fx55 at 2.6 doing 78billion instructions per-clock versus a Xeon at 3ghz doing only 31billion instructions per-clock, the difference will be very extreme, would it not? Speed is not always about the clock on your cpu.
thats what i got, they just refuse to cooperate.centvalny said:gskill 1GBLE and rock stable at 287and 3.3Ghz with phase changer.
you do know that AMD 2.2 GHz (aka 3500+) beats out intels 3.6EE in alot of things dont you??? when you compair intel and amd GHz dont mean crap.rolo said:No, I don't have an FX-55 (see sig)I was thinking about getting one, but I'd really like it to run at 3.0ghz. Otherwise it's much harder to justify spending all that cash.
