Futureproof system on a shoe string
if you want it to be future proof, dont start with 2-3 year old technology. look for a 3800x2 in socket am2, or a c2d 6300 combo. either of these should should be less than $250 or so with a decent mainboard.
Socket 939 is already obsolete. Get a motherboard that can support a quad core processors.
Future proofing doesn't exist. We don't really know what a hardware vendors are going to really be doing from month to month. Intel could release a different CPU socket tomorrow, tthere is really no way to know.
Plus, since everything changes so dramatically in 18 months or less, there is definitely no way to "future proof". Though buying into older technology, such as outdated sockets, memory technology and so on is generally ill advised because you are buying something that will have a known limited upgrade path. Therefore, future upgrades will require more drastic changes.
Taffy Apple said:
So for now is am2 the way to go?
I'd say get the C2D instead for the extra $30 ($180 for the E6300). More bang for your buck at the lower end of the spectrum. Pair it up with say a Gigabyte S3 motherboard and you'll be good to go for a while.
I guess it depends on how shoe string you mean.
future proof and shoe string are words that shouldn't be in your vocabulary, just state your needs for the machine and a budget.
the whole idea of future-proof is a oxymoron . the best that you can do is get as much useful life as you can out of a system for the amount of money involved.
the best bang for buck with some decent life in it would be some kind of core 2 setup .
a low buck core 2 running a cheap asrock 775 dual vista and retaining your old ddr 400 would be a cheap way to upgrade in stages and get some more use out of the "old" stuff . but keep in mind that that would only be a short term thing to do as a step up to a 680i or intel chipset will likely be required later with ddr 2 or ddr 3 . so you'll likely get a year or so out of a $55 mb and your old ram .
running a 965p MB with some decent ddr 2 and a core 2 would be better and offer much better overclocking if you can go for new ram ddr-2,mb , core 2 cpu and likely a new videocard . that is if you don't have a powerful videocard in pci-e allready.
there are going to be some big price drops com jan for cpu's . all the major chipsets will be out then as well . hopefully prices on ram will be less as well . and the kicker is the e-4300/core 2 will be out by then with it's higher 9x multi it should overclock well for cheap.
Here's a list of what you need:
DDR2 support
PCIe 16x, preferably with SLI support
Lots of USB 2.0 ports
Firewire
Quad-core support
Here's a list of what you don't want unless you have a specific need:
AGP
Parallel port
serial port
lots of PCI slots (PCIe 1x is going to replace it)
My advice is to buy the best motherboard you can afford and make your sacrifices at the CPU and video card level. Motherboards are a lot more stable in price and performance; chipsets and interfaces last years as high-end features, whereas processors and vidcards last months.
If you go with C2D an E6300 is well under $200, and you can get a modest video card in the same price range. The motherboard I have picked out for my next upgrade is $200 itself. RAM prices vary pretty significantly so I won't suggest the best way to spend your money there, but 2 GB can be had for around $200-250 if you go with the cheaper quality memory.
All together, the major components can be bought for around $800, depending on what you're looking for. That will get you away from major legacy issues and on to the modern interfaces. PCIe isn't going anywhere, the new sockets look to stick around for at least a few years, and DDR2 should stick around for at least several years.
Futureproof? No. Expandable? Absolutely.
Nothing is future proof.. but
ddr2 = more future
AM2 or LGA775 (with Conroe support) = more future proof
PCIe 16x slot = more future proof
IE: you want a Core 2 system (preferably) or an AMD AM2 socket system. Both use DDR2 & PCIe, both of those technologies should be around for a while. Look at AGP & DDR they lasted quite some time. You can still get up to a 7800GS on agp.
