One of the USPs of some earlier Radeons was that they could run 6 monitors, usually off 6 mini-DP ports. The Fury X has 4 ports. And a completely blank plate. Why not use that blank plate to host another 3 DP ports? Add a DVI port too if you insist.
DisplayPort MST - been in AMD cards since the 6000 series. Granted there hasn't been a lot of vendor support for it, but it lets you daisy-chain or hub up to 4 monitors from a single DisplayPort output.
The Fury X also supports up to 6 displays, provided you use MST to connect some of them.
Not many cards, even before MST, had 6 independent output ports. I can't think of any reference cards (maybe in the workstation lineups?).
I wish they would have put 6 miniDP on the back of it. I don't want to fiddle with HUB's, plus with having that many ports on the card, I wouldn't have to worry about running out of bandwidth on each port.
The current implementation only allows for 3x4K screens @ 60Hz.
The highest-end single GPU reference I/Os have changed strangely over the last couple generations.
How do we go from this 5870:
to this 6970:
to this 7970:
to this R9 290X:
to this R9 Fury X?:
to this 6970:
to this 7970:
to this R9 290X:
to this R9 Fury X?:
The 5870 Eyefinity 6 card was ahead of its time, and still is apparently. 6 mini-DP should be standard by now.
He got a titan x and he is complaining about fury x why?
Most people use just one or two monitors, so this saves money.
Also, with the exception of the 5870 , eyefinity, all of those cards were limited to four ports being used simultaneously. So we're not going backwards, since the e6 card was a promotional niche device.
defaultluser said:Most people use just one or two monitors, so this saves money.
removed
I said FOUR PORTS SIMULTANEOUSLY. Not number of displays. No card besides the Eyefinity editions came with more than 2 DP connectors.
Learn to read much?
Those with shit for brains like yourself also always forget that we had to wait two years for those promised MST hubs. This made the 6000 series four display cards for most of their useful life. But few cared, because who uses more than three?
Also, another technicality: The 5000 series does not support MST. That came with DisplayPort 1.2 in the 6800/6900 series. DP 1.1 = 1 port per-display. Every 5000 series except the e6 is limited to THREE DISPLAYS!
You know AMD could easily ship 6x mini DP ports they just have to include the adapters for FREE. But they don't want to do that because it would cost them money. There are a lot of ways this can be sliced. But ultimate if you want to blame you need to blame the display port standards people as they are the ones whom have failed to make their powerful and flexible and desirable to display makers.
AMD is not cutting costs. it is cutting sales.
there are quite a few potential buyers that need an analog solution capable of more than pedestrian 1920x1080@60Hz. And AMD ignores this by refusing to put a DVI-I port on the cards. there is no adapter to solve this issue for high end CRT owners.
there many buyers that could benefit from native HDMI 2.0. But AMD insists on keeping the ancient HDMI 1.4 port. this in turn keeps owners of 4k Tvs out of the AMD ecosystem for the time being as Fury X performance advantage is not worth the hassle and costs of looking for DP> HDMI 2.0 adapter.
I do understand that the costs of adding HDMI 2.0 and DL-DVI are negligible on a product of the this price range. We need competition, but AMD keeps making the same mistakes, over and over.
Are there really? What % of buyers do you suppose they are? 1%? Honestly.
In the era of $800 4K 40" monitors and the like, why are people still using 6 array displays?
Did the fury really ship with HDMI 1.4? good god.
Are you stating that less than 1% of Fury X buyers own 4k TVs, or are you implying that anyone buying Fury X today does not plan on getting one 4k TV in the lifetime of the video card?
Im pretty sure they are better at understanding their markets than we are.
If they made the choice, you can be reasonably sure it was was a minute number.
The 5870 6 miniDP didn't sell. 99% dont use more than 3 monitors.
At some point, sacrificing your business 1% at a time will catch up to you. Fury X is an enthusiast card. There are a fair number of enthusiasts with high speed CRTs, they sure don't want to upgrade or they'd done it by now, 4k HDMI 2.0 displays - which is a strong segment to buy 2 Fury X cards for the 4k horsepower, and Korean, single DVI-D 1440p displays that really don't need to be upgraded yet.
Out of the potential market for Fury X - I would argue the three categories above are more than 3%. And they scrap those potential customers, for what? To make the card smaller? The only group that needs such small form factor is the SFF/HTPC crowd, and no HDMI 2.0 wrecks that niche for most. Could they really have not been able to add a DVI-D connector? Or taken the time/spent the money to do HDMI 2.0 instead of HDMI 1.4? What was the point of even putting an HDMI 1.4 slot on a '4k card' to begin with? Would have made more sense to drop the HDMI port completely and keep DVI-D if they were not going to do 2.0
