- Sep 7, 2004
Its not cheating its default driver settings. It has been like that since the 6800 series, They changed the names of things in their control panel though. Performance is now called quality, and quality is now called high quality.
The drivers are set at let the application decide by default.
Also changing the quality slider also adds AA.
What? No it doesn't. Unless you are talking about AMD, which still I don't think it does.
I think thats why reviewers tend to use the in game settings vs the control panel settings.
So keep the drivers at default (which is application controlled on both IHV's) and what ever the application does is what is done.
I think what you fail to realize is that the texture filtering setting in both NVidia's control panel and AMD's CCC has nothing to do with any setting in games. Even if a game uses 16xAF, if the driver is set to "Quality" instead of "High Quality" you are going to see shimmering and blurry textures in game.
Anytime I install a new NVidia driver, the first thing I do is set the global profile to "High Quality" for Texture filtering, from "Quality". This turns off all NVidia "optimizations".
