[BB] Rick James
[H]ard Dawg
- Apr 4, 2004
PM, I have a question, I'll pay you. Urgent.
Thanks,
Thanks,
Checking account: 1234567
Routing Number: 8910111213
Send money immediately....
Seriously just ask your question. Or is it a private/personal question?
Post your FTP connection log. Sometimes you have to forward additional ports (passive mode).
If you are trying to access your FTP server behind your firewall from a computer behind the same firewall sometimes routers will just prevent it from happening. Have a friend try it if this is the case.
Are you running the FTP server on the gateway server? I've had issues with port forwarding on Windows 2k3 as a gateway, so I would try just having the FTP server on the gateway server.
Most of the time you will need to configure passive mode. Do what he said...
try a port other then 21. a high range port like
55555 or something.
can people ping your external IP address?
What FTP server software are you using?
[BB] Rick James;1031329896 said:My IP address needs to be able to be pinged correct?
Isnt he double NAT'ing ?
So your Internet connection goes like this...
Internet -> [in] Win2k3 [out]-> [in] router [out]-> computers
199.199.129.82 -> 10.0.0.10 -> 10.0.0.47 -> 192.168.x.x
you have port forwarding enabled on the router...do you have routing enabled and configured on the Win2k3 machine as well?
Im guessing the connection isnt making it through the Win2k3 machine.....
(wouldnt it be easier to have it Internet->Router (not doing DHCP) ->server (doing DHCP) -> computers)
No idea....but double NAT'ing makes things alot harder...why not just use the router as a gateway device with a static IP..then have the 2003 server give out DNS, DHCP and Gateway/subnet info
|---------------server doing dhcp
Internet --- router ---|
|---------------computer 1
|---------------computer 2
how ?
