FSR 4.1
Beaver LongTail
8-D
“AMD FSR 4.1 Update Brings Sharper Details, Smoother Camera Motion, and Better Perfomance​
by AleksandarK Today, 03:06 Discuss (9 Comments)
With the latest Adrenalin Edition 26.3.1 WHQL, AMD introduced an updated version of its FSR 4.1 upscaling technology for the Radeon RX 9000 series graphics cards. The latest update focuses on several key quality improvements that AMD gamers have long wished for, and AMD is finally delivering. In a demonstration of the technology in the Crimson Desert game, AMD showed what Ray Regeneration 1.1 and FSR Upscaling 4.1 are capable of in real-world games. For example, comparing FSR 4.0 and FSR 4.1 clearly shows that upscaling in the latest version provides much finer details of the game scenery when there are objects in motion. In the Crimson Desert game, grass moved by the wind is much more detailed now with FSR 4.1 than it was previously with FSR 4.0, which applied a kind of blurry image effect on the grass. This has been improved to reflect scenarios similar to native rendering.
Additionally, AMD showcased what its Ray Regeneration 1.1 looks like. AMD's FSR Ray Regeneration processes the noisy output that ray tracing naturally produces and cleans it up in real time, resulting in noticeably sharper and more polished visuals without requiring developers to overhaul their existing pipelines. Now, with the update 1.1, we see it delivering much better and deeper shadows, immersive lighting, and more. You can check out the images below for comparison.“
Source: https://www.techpowerup.com/347565/...-smoother-camera-motion-and-better-perfomance
AMD still has a lot of catching up to do. I found myself trying real hard to spot the differences here lol
I'm curious about performance impact/benefit. i.e. can you do more with less.
It is a significant performance hit. In Crimson Desert it's about a 15% performance hit. I don't know if it would be the same in other games though.
Crimson Desert's ray tracing barely traces any rays. So the default ray tracing quality is very lacking compared to other games. But when you enable ray reconstruction it looks a lot better. So maybe a game that does 10X or 100X as many rays the reconstruction is less costly. Maybe there is a balance to how much you rely on it and the performance hit. Or maybe that doesn't matter and it could just be better looking with more rays.
View: https://www.youtube.com/watch?v=SlRpJ553RzE
Isn't that sort of the point?
Ray regeneration is about improving performance not visuals. The entire point is it delivers the full ray traced visuals with lighter math. Using stats to infer rays that haven't been fully traced.
The advantage should be getting mid-high ray traced visuals... while only tracing a low number of real rays. This isn't the best comparison it should be showing performance. The point is yes the images should look almost identical but the regeneration version should be running 20-40% faster.
I find people spend way too much time staring at and nitpicking screenshots for these sorts of things when you often don’t notice it or care either way (visually) during actual gameplay.
With Ray regeneration. I think its important to compare the visuals but at different RT settings. As I understand the tech. It should make low RT settings look a lot more like High RT settings while mostly keeping the Low RT setting performance. (maybe I'm mistaken) I guess technically you could use regeneration on a high RT setting for a even more ultra experience. Not sure there is much to gain though. For me the exciting part of this tech is making decent looking RT that performs closer to RT off settings. :)
Can someone explain to me how FSR 4.0.2 is running on a GTX 1660? Not even badly.
I would guess it is the INT8 version that leaked. That should, in theory, be able to run on any shaders it isn't a tensor/other core type situation. So far though, AMD hasn't officially released it.
FSR is generally not very good in motion and screenshots are a very, very bad way to observe this and since I play my games in motion that is metric that makes or break it for me.
If you watch Hardware Unboxed's comparison video, we are mostly down to pick the artifacts you like better. and I think we are only 1 -2 years away from essentially zero difference for upscaling, whichever brand you choose.
Which is to say, overall, Everybody is doing quite well, now. But, each version has its own quirks, which certain games might highlight negatively.
In this comparison, FSR 4.1 generally seems to handle grass clarity and detail in motion, the best. DLSS 4.5 L blurs and dithers grass while in motion. But, is clearly better at trees full of leaves and also naked tree branches. These qualities seem to be similar in both Mafia The Old Country and AC: Shadows. Suggesting these may be general qualities of the upscalers.
FSR 4.1's texture detail and overall sharpness are improved over 4.0. But DLSS 4.5 L is even still, a bit more detail and defined. Yet------FSR 4.1 is better at minimizing Moire patterns in textures. Whereas that can be a problem for DLSS 4.5.
FSR 4.1 seems to have an issue with hard edges.
And as you mentioned, what is it actually like at actual play speed? A lot of these things are cumulative and it can then come down one artifact in particular, which can stand out here, or there.
I.E. I generally dislike DLSS 4.0 preset K. Even though it has very good overall image reconstruction and texture detail: it has a lot of problems with disocclusion. Running a character through a grassy area or an area with a lot of various details, can be very distracting with preset K.
Before 4.5, I would typically force games to use DLSS 3 preset C. Rather than 4.0 K. Also, Unreal 5's TSR is usually quite good in the equivalent of DLSS "Quality" mode. And has also been a good alternative for me, rather than DLSS 4.0 K.
I also generally like DLSS 4.5 preset M more than L. Even though L is more taxing on the hardware and is supposed to be higher quality.
View: https://youtu.be/VO7qs7s5GbA?si=s8XSVymH09UhE293
This
In my case I tend to prefer Preset K over L (depends on the game). Which at this point is what much of this is about, a mix of personal preference, the artifacts one is more sensitive, the game being played and choices of tradeoffs.
Something cool about FSR 4.1, is there is virtually no performance difference, compared to FSR 4. Whereas every new model of DLSS, 2 < 3 < 4 < 4.5: has cost more performance.
Xbox Series X Could Outrun PlayStation 5 With AMD FSR 4.1 Thanks To 2x Hardware Edge And Better SDK Support​
Francesco De Meo
May 15, 2026 at 06:26am EDT
Although such a breakthrough may feel like it's coming late in the cycle, support for the Xbox Series X and PlayStation 5 isn't going to be dropped as soon as the PlayStation 6 and Xbox Project Helix release. As we may be looking at one of the longest cross-generation periods to date, AMD FSR 4.1 coming to consoles will keep them a solid option for gamers not yet ready to jump to the next generation.
With AMD FSR 4.1, the Xbox Series X couldn strike a real win against the PlayStation 5
Since their launch, multiplatform games released on Xbox Series X and PlayStation 5 have had very few differences, and those that do exist are often too minor to affect the average player. However, according to a recent analysis from Moore's Law Is Dead, AMD FSR 4.1 coming to RDNA 2 GPUs in the near future could allow the current-generation system from Microsoft to strike a major victory against the competition thanks to its hardware and software development kit.
"Could FSR 4.1 come to the current gen game consoles? I'm talking about Xbox Series X, Series S, and PlayStation 5. And the short answer, I believe, is actually yes, but it's not a clear-cut yes," said the YouTuber in a new video. Showing a chart comparing the INT8 performance of AMD GPUs and systems, the PlayStation 5 Pro obviously dominates with 300.0 TOPS, but the Xbox Series X with its 48.6 TOPS is notably ahead of the base PlayStation 5, which sits at 20.6 TOPS (with aFP16 fallback), and the Xbox Series S at 16.0 TOPS. This indicates the Series X could run the new upscaler better than half of the GPUs systems that will soon receive FSR 4.1 support.​
"I think Xbox Series X is going to be fine at running this. Will it get the same boost that PS5 Pro gets from PSSR 2? No, it won't. But it'll get a nice boost," said Moore's Law Is Dead. "I don't think it'll be huge, but I do think there's a chance you could have the Xbox Series X running like a higher quality mode of FSR 4.1 than what the PS5 can handle. And that is just a clear-cut advantage to Xbox Series X next year, presumably when they get this."​
In addition, it seems developers could find it easier to implement AMD FSR 4.1 on Xbox Series X thanks to the Xbox SDK.
"I talked to some game devs today... one thing they brought up about the PlayStation versus Xbox SDKs is that Xbox already has... some plugins for FSR 3 and later... Sony stopped upgrading FSR plugins at around 2.2. I think there might still be ways to get FSR 3.1 into a PlayStation game, but it's not as easy as just a direct plugin to activate it in the SDK. And so Sony would need to actually wake up and start adding support for later FSR than 2.2 to even get to 4.1."​
Moore's Law is Dead speculates that Sony may have focused entirely on the PlayStation 5 Pro’s PSSR upscaler, leaving the base console on older FSR versions deemed good enough for it.
https://wccftech.com/xbox-series-x-outrun-playstation-5-amd-fsr-4-1/
Francesco De Meo
PS5 doesn't have all the same hardware features as RDNA2.
They left out mesh shaders, for Sony's internally developed "Geometry Engine", which they worked with AMD to customize and implement.
And they left out INT8 support. Which is what FSR 4.1 would use, to run on RDNA2 and Xbox Series X.
PS5 Pro again went custom, with PSSR. Rather than simply adopting FSR. But.....FSR 4 is actually born from Sony and AMD co-developing ML solutions. Which resulted in PSSR and subsequently, FSR4.
So is fsr4 coming to steam deck at some point? What Gen rdna is steam Deck?
It's RDNA 2 so, in theory, you'll see it for that in a year-ish time. The issue will be performance. Since RDNA 3 and 2 don't have silicon for the tensor math, it gets run on shaders which means it steals rendering performance, not something the Steam deck has a ton of to start with. Also it sounds like RDNA 2 will be a bigger performance hit for it. It is unclear how well it will work
well since valve develops the AMD linux drivers, hopefully they can accelerate the development of RDNA2 on steamdeck. Valve definitely has more of an interest in getting it working ASAP than AMD.
That depends on AMD giving them access to the model weights and training data, and Valve being willing to spend money on training it, as well as having the kind of scientists who are good at that. These advanced upscaling models are inference based, like LLMs, they are trained rather than programmed and it is a real combination of art, science, and a shitload of computing power to do it well.
  1. FSR 4.1 is coming to Radeon RX 6000 series graphics cards. Tuned and optimized from the 6900 series down to the 6400 class.
  2. FSR 4.1 is coming to APUs.
    1. All Gorgon Halo and Strix Halo
    2. All Gorgon and Strix Ryzen 9
    3. All Z2E and Z2A
    4. working hard to bring FSR to more APUs in the future.
  3. FSR 4.1 is coming to XBOX. Optimized for
    1. ASUS_ROG Xbox handhelds
    2. Xbox Series X | S.
  4. soon, FSR is coming to Vulkan.
  5. Ray Regeneration is coming to more games.
  6. FSR Frame Generation gets more consistent frame pacing, for smoother gameplay.
https://x.com/jackhuynh/status/2112555792079417520?s=20
FSR Redstone is now in more than 400 games on Radeon 9000 series graphics cards.
    3. All Z2E and Z2A
About freaking time. I like how 6000 owners gotta wait until Xbox Series X | S owners get FSR 4.1.
There are multiple layers to this thing.
A. FSR 4 on RX 6000 was announced for sometime in 2027. This release is actually a lot earlier than AMD had said it would be.
B. Xbox supports INT8, RX 6000 does not. Its likely that Xbox will have an INT8 version. Although it could still be a "Lite" version of the algorithm, compared to what RDNA4 cards use
C. PS5 recently got QSSR, even though it doesn't have any newer instruction sets normally associated with running ML derived code. and it seems to perform only a little worse than FSR3, while delivering a meaningful improvement to image quality. I am betting that RX6000 GPUs are essentially getting a port of QSSR.
I just now actually watched the AMD official video and....they also made special version of FSR 4.1 for their handheld APUs. It will be interesting to see if any games will use it on Nintendo Switch 2. There's a chance it could give better overall results than the current DLSS algorithm available to NS2 developers.
My guess is they won't port it to the Switch 2 because they don't want to make competitor hardware look better. Remember AMD's handheld APUs are x86 CPUs with RDNA GPUs. The Switch 2 is an ARM CPU with an nVidia GPU. So it would be a completely different porting job, different hardware target, and if it worked and it looked better it would make a competitor's product look better. Can't see them spending the time on that. The reason older FSR versions got used on the Switch is because they are open source and they don't need any special hardware to implement, they run in shaders. So AMD didn't port them, the companies making the games did. FSR1 in particular, which is what a lot of Switch 1 titles used, requires very little effort and is more or less something you can slap on after the fact.
Also, I'd imagine that DLSS will be better. Say what you want about nVidia, but they have consistently had the best quality upscaling. FSR 4.1 is a major step to equalizing that, but nVidia is still ahead and continually pushes the envelope. Given that, and that it is their hardware, I'd imagine they can get the best results.
Even thought I know it does: I did indeed not exactly think about the specific fact that Switch 2 has an ARM CPU.
But...I wonder if that really matters, if the upscaler runs completely on the GPU. QSSR If i'm not mistaken, is purely shader instructions and incorporates packed math. And its likely that the version of FSR 4 for RX6000 is also run as a shader/is very similar to QSSR. If the CPU architecture affects a GPU shader at all.... its probably pretty basic translation. Its not like hardware Ray Tracing where------a meaningful portion of the BVH calculations actually happen on the CPU, working together with the GPU hardware, to combine for the final visual effect.
Additionally, the modding community has ported DLSS 3 model E, to be run as a GPU shader so that AMD APUs can utilize it:
https://wccftech.com/helixsr-mod-dlss-3-7-steam-deck-amd-handhelds-faster-fsr-4/
Its also useful to take a look back at how the Switch port of No Man's Sky eventually replaced part of its render pipeline, to directly incorporate a highly customized version of FSR2. And the results (especially after an update to that update), are basically as good as DLSS3---while working with a much lower internal resolution than would normally have been thought to be "ok" for DLSS, let alone FSR2!!
I agree, it probably doesn't REALLY make sense for AMD to make a version of FSR4 available for Switch 2. But, I am sure it could be done pretty easily at this point. And it would look very good.
Apparently the version of DLSS currently available for Switch 2, is still pretty heavy on resources. There are plenty of games which don't use it, because it can be a detriment to performance. I'm sure Nvidia will improve the model over time. But, its difficult to understand what the heck is going on with Switch 2 development. Because Nintendo is reportedly still selectively very protective about letting some developers have access to Switch 2 dev kits.
I guess my point there is that Nvidia may very well be ready to update Switch 2's DLSS------But, Nintendo may not be easy to work with on such things. And further, its probably impossible to predict when such an update might actually be seen in a released game.
The problem is those two statements are kind of opposed. What I mean is if they port FSR4, and it looks good, then it will be heavy on the resources. To reduce the load it has to be a cut down network. That won't look as good. Also I believe the Switch 2 has tensor cores for DLSS to run on. If AMD ran purely on shaders it would hit even harder since there is hardware not being used.
For small chips it is just a hard tradeoff of IQ vs speed. We see that on the GabeCube with FSR4: It hits harder than we might want because the GPU is so small.
