FSB oc damge to mb
dp0001
OC's within the MB's FSB range - can it damage the motherboard on the long run, would like to know if it happened to anyone thnx
Overclocking doesn't hurt anything as long as you don't need to add too much extra voltage to keep things stable and as long as you keep your parts at a reasonable temperature.
Every processor I've ever had since My Pentium2 233 has been subjected to some overclocking and never once have I had anything fail.
Processors will tell you when you are pushing them too hard. If they can't pass a good long run in Prime or Orthos then that's a sign that you are trying to overclock your combination too much.
PS: Check out my sig and you will discover that I'm crazier than most with the MHz and volts so no worries.
Speed doesn't kill.
Heat and Voltage does.
Let your stuff get really hot = problem
Give your stuff lots of extra volts = problem
and what would be more harmful multiplier raise or fsb - sorry for the noob questions/ i'd rather post on my forum 1st than mess it up
On most CPU's you won't be able to raise the multiplier. You can only do that on the high end FX or EE chips.
you cant force a cpu to run at a certain multi, speed or fsb, it will just fail to post. you can force too many volts. and you can let it get too hot.
