Ins0mnyteq
- Nov 11, 2013
For sale is my for NAS i used for backups, Comes with no drives, Clean unit has a small ding on the top otherwise is mint condition. upgraded to 8GB of RAM , HYPER-X Impact
here are the specs from the website
Looking to get $275+shipping to the 48 connected, paypal only.
14 nm Intel® Celeron® N3150/N3160 1.6 GHz quad-core processor
Total Memory Slots 2, SODIMM DDR3L-1600
(*For dual-DIMM configurations, you must use a pair of identical DDR3L modules.)
Flash Memory 512MB
Maximum Number of Hard Drive 4
Hard Disk Drive Hot-swappable 3.5" or 2.5" SATA 6Gb/s, SATA 3Gb/s hard drive or SSD
LAN Port 4 x Gigabit RJ-45 Ethernet port
USB 4 x USB 3.0 port (Front:1, Rear:3)
Support USB printer, pen drive, and USB UPS etc.
Video Output 2 x HDMI, up to 4K 2160P 30Hz Ultra HD support
Audio Input 2 x 6.3mm microphone jacks (dynamic microphones only)
Audio Output Line Out Jack (for amplifier or headphone amplifier)
LED Indicators Status, USB, HDD 1-4
LCD Panel Mono-LCD display with backlight
Buttons System: Power button, USB one-touch-backup button, Reset button
IR Receiver ✔, Support QNAP RM-IR002, RM-IR003 and MCE-compatible Remote Control
Other Interface Console port (system maintenance)
Alarm Buzzer System warning
Form Factor Tower
Dimensions 177(H) x 180(W) x 235(D) mm
6.97(H) x 7.09(W) x 9.25(D) inch
Weight Net: 3.65 kg (8.04 lbs)
Gross: 4.65 kg (10.24 lbs)
Power Consumption (W) System sleep mode: 1.61W
HDD standby: 18.86W
In operation: 32.35W
Sound Level* Sound pressure (LpAm) :19.7 dB(A)
Temperature 0-40˚C
Relative Humidity 5~95% RH non-condensing, wet bulb: 27˚C
Power Supply 96W AC adapter, 100-240V
Fan 12cm quiet cooling fan (12V DC)[/spolier]
Flash Memory 512MB
Form Factor Tower
HDD standby: 18.86W
Temperature 0-40˚C
