Yep, been working fine. Been playing Mirror's Edge with Physx enabled just fine. You just have to use the 8 series Physx drivers as 9 series don't work.
Can definitely tell the card is working because when you disable it or use newer drivers your frame rates suck with Physx on. Smooth as silk with it on.
