FS/FT Tuner Cards, Antec HTPC case
CrimandEvil
Dick with a heart of gold
I've got some extra gear laying around; need to clear some space, you know? :)
I will trade for a Hauppauge 1250.
Diamond 650 Tuner PCIe - $40 Shipped
Records one SD channel and one HD channel (ATSC or QAM). Great card, just got it and used lightly for two weeks, transferred HTPC into a new case and the card is too large for it.
Sapphire 650 tuner PCI - $35 shipped
Records either SD or HD (ATSC and QAM). Another great card, used it for several years and was very happy with it.
Antec NSK2400 - $70 shipped
NOTE: no fans and no PSU included
Awesome case, used it for several years but I've recently moved to a mITX HTPC so no need for a larger case. Some light "wear and tear," mostly it's just a scratch or two on the bottom of the case. I have removed one drive cover and modded it to stealth a DVD drive (using some double sided tape).
which case did you go with? are you using usb tuners or hdhomerun?
Posted via [H] Mobile Device
Tuner free (TV is Hulu and, ahem, other sources), lots of Netflix streaming too but that does remind that I will trade for a Hauppauge 1250. :)
I'm working with an LC19 that I need to make a new front panel for (it fits 5.25 drives now, relocated HDD were the PSU was, using a Pico with it too). The problem with the LC19 and a 5.25 drive is that it cuts down on the length of your expansion cards. My 650 tuners are about 5mm too long. : / So I get to sell them and/or trade for a 1250 which is short enough.
If only this case took a full size ATX mobo. Le sigh.
Bump for sick HTPC gear.
