Johnyblaze
- Nov 9, 2003
SOLD ITEMS
1x - Monsoon Hardline Pro Cutting Kit 3/8 x 1/2 (13mm)
1x - Monsoon Hardline Pro Mandrel Kit 3/8 x 1/2 (13mm)
1x - EK-XTOP Revo Dual D5 PWM Serial - (incl. 2x pump)
2x - EK-XRES 100 D5 PWM (incl. pump)
2x - EK-RES X3 - TUBE 250 (204mm)
2x - EK-RES X3 - Multiport Top - Black
1x - EK-RES X3 - Internal Tube 12/16 - 40mm
1x - EK-RES X3 - Tube 150 (104mm)
1x - EK-RES X3 250 Lite Reservoir
8x - Noctua NF-F12 PWM "Linus Tech Tips Special Edition" 120mm Cooling Fan
6x - Noctua NF-A14 PWM "Special Linus Tech Tips Edition" 140mm Cooling Fan
3x - Noctua NF-F12 PWM 120mm Case Fan
1x - Noctua AAO Frame Design SSO2 Bearing Quiet Fan(NF-A9 PWM)
2x - Noctua NF-A8 PWM Premium 80mm PC Computer Case Fan
1x - NZXT AC-HUEPS-M1, HUE+ Smart RGB Color Changing Digitally Controlled LED PC Lighting (Black)
1x - Black Ice Nemesis 120GTS® Ultra Stealth U-Flow Low Profile Black Carbon Radiator
1x - Black Ice Nemesis 240GTS® Ultra Stealth U-Flow Low Profile Radiator - Black Carbon
1x - Black Ice Nemesis 280GTS® Dual-Core Xtreme Profile Radiator - Dark Matter
2x - Black Ice Nemesis 360GTS® Ultra Stealth U-Flow Low Profile Radiator - Black Carbon
1x - EVGA 120-G2-1600-X1 SuperNOVA 1600 G2 1600W 80 PLUS Gold ATX12V & EPS12V Power Supply
1x - Aquacomputer Filter with Stainless Steel Mesh, Ball Valves and Mounting Plate G1/4
1x - Caselabs MAGNUM SMA8
1x - Black Ice Nemesis 480GTS® Ultra Stealth U-Flow Low Profile Radiator - Black Carbon
1x - EK-FB ASUS M8I Monoblock - Acetal + Nickel
