| Attribute | Specification |
| Series / Model | Samsung PM9A1 (OEM version of 980 Pro) |
| Capacity | 512 GB |
| Form Factor | M.2 2280 (Single-Sided) |
| Interface | PCIe 4.0 x4 |
| Protocol | NVMe 1.3 |
| Controller | Samsung Elpis (S4LV003) |
| Flash Memory | Samsung 128-layer TLC (V-NAND V6) |
| DRAM Cache | 512 MB LPDDR4 |
Because this is an OEM drive, it is usually managed directly by the computer manufacturer (such as HP, Dell, or Lenovo) rather than Samsung's retail software (Samsung Magician). If you need to update its firmware, you should check the support page of your specific laptop or pre-built PC manufacturer.
