Dec 27, 2010 #48 T THE JEW (RaVeN) Limp Gawd Joined Feb 14, 2003 Messages 404 Questions: 1.) Which version of the n4250QE is it, the S4985 or the S4985-E? Does it support only Barcelona or also Shanghai? 2.) I presume the cpu's are Barc's. What revision are they (ie. B2, B3)? Do you have the stepping model? 3.) Are you willing to part it up to make smaller combos (ie. procs, mobo, coolers, RAM)? Thanks.
Dec 27, 2010 #49 6 6foot4geek [H]ard|Gawd Joined Apr 27, 2008 Messages 1,287 The S4985 version, and yes I believe only Barcelona Chips. The chips are Barc's and they are B1 stepping and I will part if the price and amount of parts is right. Thanks!
Dec 27, 2010 #50 Fastvan67 [H]ard|Gawd Joined Aug 28, 2006 Messages 1,420 That is just SOOOOO pretty!
Jan 5, 2011 #54 6 6foot4geek [H]ard|Gawd Joined Apr 27, 2008 Messages 1,287 bump added an update in the first post
Jan 14, 2011 #56 J jeremyshaw [H]F Junkie Joined Aug 26, 2009 Messages 12,511 badabump for a fellow 16core owner
Jan 14, 2011 #58 V Valkhorn Gawd Joined Apr 23, 2007 Messages 955 I could really use a machine like this but I don't have the budget for it (even though my Newegg account has the room for it). The only thing I don't like are the heatsinks because I'm not sure it will fit in a standard 4U case.
Jan 14, 2011 #59 R rickss69 Limp Gawd Joined Jan 3, 2010 Messages 328 What kind of time you get on a WPrime 1024M with that?
Jan 15, 2011 #60 J jeremyshaw [H]F Junkie Joined Aug 26, 2009 Messages 12,511 If he doesn't get numbers by tomorrow, PM me and I will append them to this thread (we have really similar builds with only 100MHz difference, so )
