Frys SSD
I bought 2 of these for RAID 0. Any one has experience with these? Are they much better than the WD Black?
Thanks.
Thanks.
If speed is what you're going for then they're WAYYYYYYYYYYYYYY faster than WD Blacks. For capacity, not so much...
Even the slowest SSD should outperform any mechanical drive.
Thanks.
Haha you should be very happy. I went from a 1tb Black to an Intel x25-m g2 80gb and the difference is night and day on general usage.
I finally got a job and started working 2 weeks ago so I could buy some toys now. The prices for SSD is coming down slowly so with rebates, it should be about 35c per gig. I am going to run them in RAID 0 with my LSI SAS controller.
With SSD drives, is there an advantage to run them in RAID 0? If not, I just need the one bigger drive to give me 240GB instead of just 120GB which is way too small for the main drive.
I am thinking of running them as the main drives to boot and run Windows and put all of my office and applications software on the WD Blacks and put games on the SSD to play them some times.
How are these drives compares to the OCZ?
What a lousy title and post OP. At least include the model, size & price of the ssd.
comparison:
http://www.anandtech.com/bench/Product/400?vs=643
as for two in Raid 0, remember that Trim only works on intel 7x chipsets.
These have been available for quite a while, I picked up several of the 60GB for $40 before they went out of stock locally.
So I guess there's no benefit to running RAID0 since TRIM won't work?
I have the older Intel X58 chipset and i920 processor, will that work with TRIM? Would Intel RAID0 from the Asus P6T board works with TRIM?
This is the SAS controller that I have.
Thanks.
Thanks.
The performance advantage from RAID 0 will far outweigh the performance loss over time from not having TRIM. Unless you're consistantly accessing the drive with no idle time, Hardware Garbage Collection is good enough on its own with modern SSD's that the loss of TRIM won't really be missed.
Since we don't know his usage patterns and 120GB is on the small size, I'd recommend setting aside an extra ~6-8GB per drive. Depending on the ssd controller/firmware, The additional spare area isn't always needed (or even utilized) , but it avoids worst-case scenarios when filling the drives.
Well we can ask him...
Will your usage pattern be such that the drive never sits idle? But I agree, setting aside space is always a good thing on any drive.
And by accessing I mean writing to it. Reading from it doesn't need trim or garbage collection involved.
I am currently having 2 WD 1TB each HDs on my RAID 0 with the same controller. I have 24GB of RAM so I turned off virtual memory on the system.
I would like to use the 2 Force3 SSDs as my main Windows 7 X64 drive and nothing else. Since my main drive usually have about 200GB+ of software installed, I might use the SSDs with Windows, and put all of my software on my secondary drive. I might use the SSDs RAID0 to put some games and some times video editing.
I have a few questions:
1) Should I set my RAID0 to 128K or leave it as default with 64K? Most of my files are big but I don't know about the every day usage files that would cache the SSDs.
2) I got Intel RAID0 ICH10R and this SAS LSI controller. Which controller should I use to maximize my speed for the SSDs? I would think the LSI controller but the Intel controller can be hacked to run RAID0 and TRIM but there's little info on it so I am not sure I want to risk it since I have no cash to upgrade right now. I have the i920 running at 4Ghz right now so the system will hold me for a while. I have the Asus P6T. Either way, I am going to be running 2 RAID 0 arrays, one set with the SSDs and one set with the WD Blacks.
Thanks.
Could you elaborate on this process more? More so, could you show and describe that steps on how to set this up?
Thanks.
I hate Fry's so fucking much. Every time I go they won't price match or won't sell me goods on the shelf. Can't wait to hear their bankruptcy announcement.
I have read that these drives were having lots of problems, do they still do?
Thanks.
