Well, after failing while trying to use my dremel tool I decided to go for the easier option.
Everything turned out GREAT on the practice acrylic!!
Taping down the stencil..
Peeling back the stencil after tracing design onto the painters tape.....
Results of stenciling...
Cutting the design out of the tape...
I did three wet-laid coats and allowed them to dry 10 minutes inbetween.
AAAAAAaaaaaaaaaaaaaaand VIOLA!!!!
The result is slightly raised off of the acrylic and is VERY durable. I tried scratching it with my fingernail and it held up great!
Friday I do the big stencil on my Lian Li case window.
