Hoping someone can help with an idea. I have an ASUS P8P67WS Revolution mobo with USB 3 support. It does not have an option to support front panel 3.0 ports. I am purchasing a Lian Li PC-V2120X with usb 3 on the front. Any way to connect the ports to the back port on the board I/O panel like a hub? I assume I can start splicing wires, but I don't want to hack anything up if I don't have to. Don't think anyone makes a cable with a front panel header port on it and a regular male usb 3 on the other end...
In case it helps:
Case
Motherboard
In case it helps:
Case
Motherboard
