1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? moderate gaming, web browsing, picture editing
2) What's your budget? Are tax and shipping included? ballpark of $1500 after shipping
3) Where do you live? Janesville, WI
4) What exact parts do you need for that budget? everything (case, psu, HD, CPU & fan, graphics card, mobo, dvd-rw, RAM, monitor).
5) If reusing any parts, what parts will you be reusing? only may reuse some sata hd's.
6) Will you be overclocking? No
7) What size monitor do you have and/or plan to have? Want at least a 22" monitor.
8) When do you plan on building/buying the PC? next 30 days
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? nothing special, USB 3.0 would be nice, but not necessary. At least 1 PS/2 port if possible, at least 6 usb ports. decent onboard sound (5.1), and onboard NIC.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit? Need a copy of Windows 7 64bit included in the price as well.
So basically a from scratch computer. All the hardware, including monitor and the OS all for the low low price of $1500 (give or take $100).
Moderate gaming, otherwise pretty standard use. No overclocking.
Would like...
22" or bigger monitor
Triple or Quad Core (AMD or Intel, doesn't matter)
Fast HD or SSD.
Windows 7 64bit
4Gb RAM minimum
I'll post some stuff I came up with soon. Let me know what you think. Thanks!
Would like...
Fast HD or SSD.
Windows 7 64bit
4Gb RAM minimum
