From AMD to Intel
paddi70
Current system down below in sig, look at a chang to intel C2D, want to keep graphic cards so need SLI, and want to OC CPU, it will be a conroe.
What motherboard?
I'd wait and see what the new SLI boards look like. They should be out at the beginning of November supposedly.
None of the good Core 2 Duo compatible motherboards officially support SLi. That is if you plan on overclocking. The P5W DH mentioned, is a great board, but it is NOT SLI compatible as such.
You can use hacked drivers that don't support the 7950GX2 and 7950GT or you can use the ULi patch in order to make it work with any graphics cards. Even so, it is hard to say how well that will work down the road as drivers and hardware changes.
Are there any hacked drivers for the 7950GX2 ?
