This is for a friend of mine. He'll be using it primarily for Everquest 2 and a few other games (Rift, Star Wars the Old Republic, SC2, Bioshock 2, Mass Effect 2, Dragon Age, and Dragon Age 2 when it comes out).
At any given time he might be running 3 instances of Everquest 2, so I guess keep that in mind.
Gaming PC
Tax included, looking to keep it under $1500 CAD
3) Where do you live?
Vancouver, BC
Case, Heatskink, CPU, RAM, SSD, Motherboard, Power Supply, Video Card, optical drive
Nvidia 9800 GT if it won't hurt overall performance
6) Will you be overclocking?
yes
I have a 23" monitor and a 19" secondary display
soon as I have the parts sorted out
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Raid and SATA2 would be enough (Raid for future use)
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Windows 7 64-bit
Gaming PC
Vancouver, BC
yes
Windows 7 64-bit
