A friend of mine is trying to convince me that the PSU that came with his case is "good enough." Anyone want to help me convince him otherwise? Here are its basics:
Manufacturer: COLORSit (that's how it's written on the PSU itself)
120mm fan
480W Max
+3.3V 30A
+5V 45A
+12V 15A (This makes me worry a LOT)
-5V 1.0A
-12V 1.0A
+5VSB 2.5A
It's also not amazingly heavy- couldn't be over 2lbs.
At first we figured that between its fairly high rating and the 120mm fan, it would at least be worth trying- how many crappy companies do you know that actually try to look impressive? Now that I've actually had it in my hands and read the label, I'm afraid to even plug it in!
He is getting my old computer with a few changes.
Barton @ 2.3GHz (209x11, 1.8ish volts), 512MB DDR (running at 3.2V for low timings, it's CH-5), one HD (and a dual-fan cooler he picked up, though I don't think he needs it), one DVD, and a GeForceFX 5900. It'll also be running a 92mm CPU fan, besides a few 80mm case fans. Between the CPU, drives, and video (and a wireless card for good measure), I can almost guarantee that the 12V line won't handle it well. Oh, and the case has a nice, big, bright LCD panel on the front for temps and such.
120mm fan
480W Max
+3.3V 30A
+5V 45A
-5V 1.0A
-12V 1.0A
+5VSB 2.5A
