wraieghaeien
- Nov 20, 2003
As long as they have adequate cooling, running them 24/7 full blast will have no discernable affect on CPU lifetime.
I mean hell, there are servers out there that serve up databases 24/7 and are pegged like mad and there isint a huge problem with CPU's burning out.
When you are talking about the CPU itself, as long as it dosent overheat, no ammount of work is really going to degrade it, or affect it. Its a semiconductor, it moves electricity around. Yes technically if you look at it in the LONG LONG term, you may decrease the life of a cpu by a few percent, but as it has been said time and again, by the time you run into the issue of your constant use killing the CPU, it will be soo out of date as to not be funny.
On a side note just FYI, I still have a p2 266 folding 24/7/365. Yes admitadly it runs other applications, but the cpu usage on it has been pegged at 100% since I bought the thing years ago. It hasent all been folding, some of it has been looking for little green men, and some of it was crypto stuff, but none the less the CPU was bein worked.
Other than a few case fans, (moving parts do die) its still runnin like a cham after years of 100%
![](http://www.hardfolding.com/ftag1.php/mem/133.png)
