Friend needs new videocard
Potatocodone
So my friend needs a new videocard.
His specs are:
-Intel e6400 @ 2.13GHz (stock hsf)
-EVGA 680i SLI motherboard
-4GB DDR2-1066
-OCZ GameXStream 700watt PSU
-24" LCD 1920x1200
-EVGA 8600GT
He plan on playing games like CoD 5 Modern Warfare 2. We narrow down the choices to:
-GTX 260 896MB GDDR3
-GTX 275 1792MB GDDR3
-ATi 5xxx series?
My friend is more keen to stick to nvidia and the budget is under $300.
He plans on either OCing his C2D to 3.0GHz or upgrading to q9550.
What would you guys suggest and why? Thanks for your help guys.
My votes go to the Radeon 4890, 5770, or Nvidia GTX 285 (if it can be found for around $230).
Why, why, why does he want to stick with NVidia when there are AMD cards that perform better, that are cheaper?
I would probably get a 4890 or a 5770 (if you really want DX11 and Eyefinity with this GPU). Ideally, you should see if you can get hold of a 5850 somewhere; they're under $300 and are absolutely awesome for the money.
Cause that's how the world works.
MW2 is a straight up console port. Anything with more than a 9800gt will run it at lightspeed, regardless of resolution (because there is a limit to how far cards can even display :eek:).
I see the XFX 5770 1GB is going for $174.99.
I know the GTX 260 goes around this price range.
How does the ATi 5770 go against the GTX 260?
5-10% slower than gtx 260 but 5770 brings Eye-infinity, near half power usage and directx 11 support.
