Okay, so I rebuilt my friend's PC a few months ago. We got him an Antec P180 case and a replacement abit mobo for a p4 northwood. Everything starts up fine. There was a nagging issue where the machine refused to boot past POST (simply turning itself right back off) for a few times before allowing the machine to run. Further replacement parts and BIOS updates later, the problem is down to 2% of startups does this occur.
However, there is a new issue. About a week ago he informed me that when opening the front panel to turn on the machine, a spark jumped from his finger to the case. Then the power button didn't work until he turned off the power strip the PC is plugged into and then back on.
Then he tells me yesterday that when he went to plug in his Portable HDD into a front panel USB port that another spark arced from the USB port to the plug. The HDD was not powered or plugged in at the time. The computer froze at this point and he had to hold the power button to get it to turn off. Once again, he had to turn the power strip off and then back on for it to even consider booting up again..
From what I can tell, the motherboard is properly mounted. I can't find anything along the paths that would be causing this... Is there something wrong with PSU? Or does this have something to do with the power strip...
I won't be able to touch the machine again until Sunday at the earliest, as I will be out of town.
Any help at all would be greatly appreciated. Thank you in advance.
