Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Well I think my PSU kicked the bucket as when I try to switch everything on it spins for like a second then powers down. I tried the paperclip trick and it does the same thing, my PSU is dead then correct?
Disconnect all of your drives and accessories. Them jump start it and see what happens. It sounds like a bad component is causing the unit to shut off by tripping the protection circuit. Normally when a PSU dies it won't do anything at all because the main fuse blows.
Thank you so much I unplugged everything and re-plugged everything back in and it worked, everything spun up and my computer is working fine, I thank you for your honest answer and not just saying "Looks like it is, buy an OCZ or PC Power and Cooling PSU"
