http://www.eclipsecomputers.com/cart.aspx
My friend wants to build a PC it seems pretty good but like to make sure
Input please
Input please
Or at least post a bloodly PC build list.
Not bad, you should get DDR2 800 RAM which is good enough for that Q6600 cpu. I would get a 8800GTS 512MB video card as oppose to that 320MB 8800GTS.
How in the hell do you see a build when none of us do?
I think he's being funny.
http://www.eclipsecomputers.com/product.aspx?code=CPI-Q6600
http://www.eclipsecomputers.com/product.aspx?code=MEO-D2-2048R6K
http://www.eclipsecomputers.com/product.aspx?code=PSC-520RP
http://www.eclipsecomputers.com/product.aspx?code=CAN-XZERO
http://www.eclipsecomputers.com/product.aspx?code=HFZ-NV120
http://www.eclipsecomputers.com/product.aspx?code=MBA-P5KEWIFI
http://www.eclipsecomputers.com/product.aspx?code=GCB-XN96GT512
http://www.eclipsecomputers.com/product.aspx?code=HDW-320KS
The going rate is $5 per click. Otherwise, please list out the part names along with those links. Thanks.
