MetricGnome
- Feb 15, 2010
Hi,
I am planning to build a Freenas box using ZFS within the next month. I plan to use this as personal file/media storage. Backup is not important to me, however redundancy/protecting my data is. In the future, I plan to expand this box to serve both my desktop and an HTPC or two.
Personal file/media server
$600 US
3) Where do you live?
Phoenix, AZ
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything~
Nope
6) Will you be overclocking?
Nope
Headless somewhere
Within a month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Firewire would be nice I suppose, big fan of lots of usb ports, will be using software raid
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Freenas
As I only have $600 US to spend, I'd like to focus the majority of my cash on the most cost effective hard drive count to storage space ratio possible. I plan to expand this box as much as possible in the future and use it for everything with minor upgrades here and there when needed.
My build:
PSU: CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified
Memory: G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit
Mobo: Intel BOXDH55HC LGA 1156 Intel H55 HDMI ATX Intel Motherboard
CPU: Intel Core i3-530 Clarkdale 2.93GHz LGA 1156
Case: NZXT WHISPER WHI - 001BK
Drives: Western Digital Caviar Green WD15EARS 1.5TB SATA 3.0Gb/s 3.5" Internal Hard Drive x4
Total before shipping: $984.91
Thanks!
$600 US
Phoenix, AZ
Everything~
Nope
Nope
Headless somewhere
Within a month
Freenas
My build:
Thanks!
