FreeNAS build
trick0502
So I am looking to build a freeNAS box.
FreeNAS
I am trying to keep it under $200
MA. I could make a microcenter run, but it is about 2 hours round trip.
Cpu, mb, psu
I have a case, 4x4gb ddr3 ram, 4x2gb hdds, 8gb flash drive, dual nic card
6) Will you be overclocking?
No
I'll be running headless
Within a week or two
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
I need atleast 6 sata ports
FreeNAS is free
I know ecc memory is better, but I aleady have 16gb of non ecc memory. Should I go 1150 or fm2+?
Go FM2 with your current RAM:
$65 - AMD A6-6400K CPU
$75 - Gigabyte GA-F2A88XM-D3H AMD A88X mATX Motherboard
$64 - XFX TS Series XFX TS 550W PSU
Total: $204 shipped
That mobo has eight SATA ports.
