Free IMB flash drive
Status
Not open for further replies.
This was posted in slickdeals. They said some people had to refresh over and over for minutes to get it to load.
Still waiting for it to load. Anyone have issues with the state part?
I got firefox, chrome and ie 8 all going. Seems the state box is causing a issue though. I will keep trying though. Thanks
Code:
Our apologies...
The document you requested does not exist on this server or cannot be served.
Please double check the URL or use the search function on this page to find what you are looking for.
If you know you have the correct URL but are encountering an error, please let our Webmaster know at http://www.ibm.com/contact/query. Thank you.
404 Not Found
I was able to get it to work earlier. Looks like now it gives an error, but goes through after a few mins of trying.
-Xzi
Thank you for requesting an 8GB USB key loaded with the CIO Reader. It will be sent to the address you provided.
Finally! Thanks OP....
Thank you OP.
Mine went through the first time using Chrome :).
How are you guys getting this to go?
Are you typing in the info, then when you get the "apologies" screen, hitting back and then submit again?
worked early this morning from home, tried from work and they removed it now.
Code:
Our apologies...
404 Not Found
Same here.... let us know if you figure out a way around this error.
What's weird is, the order form loaded up fine the first time but I accidentally refreshed and I've been getting the error page ever since.
can not get the state to work in any browser
same thing happen to me.. state was grayed out. i hit submit anyways and it returned back as... error you have not selected a state.. then state option was enabled lol.. selected state.. hit submit.. alls good. even got an email saying that i'll get my usb key :)
Nice. It didn't error for me this time, instead kicking me back and saying "Please select a state", with a drop box that worked for once. One for me!
didnt work for me a couple hours ago, worked fine just now.
I finally got through with mine. By hitting refresh and finally got the state to work so i could choose. So after that i had to do back and f5 over and over to get it to go. After the numerous errors it finally went. So from 9:44 pm to 12:44 a.m i finally got a usb drive email. So 3 hours of trying and now if i even get one.......
for those having problems choosing a state, switch the country to something else, click outside the drop down box then switch it back to US
I left that apologies screen up for like an hour, came back and refreshed and it went through.
Status
