You can also use any codec you want while other rippers (iTunes and WMP, for example) only give you a few options.BillLeeLee said:That's pretty much the benefits of EAC.
EDIT: Forgot to point out that CDex (among others) also do this.
B. W. said:You can also use any codec you want while other rippers (iTunes and WMP, for example) only give you a few options.
Yes.DigitalMP said:Does CDex correct errors on the fly, as EAC does?
XxMe_LoCoxX said:why not just use winamp?
it has a cd ripper and it rips at good quality.
Crude?Whiznot said:Fryguy8 what are the advantages of Foobar over Mediamonkey? Mediamonkey supports ASIO output, mass tagging, file monitor and file conversion. The learning curve for Foobar seems steep and the interface appears crude.
B. W. said:
