Not sure whether this is the right section for this post, but figured since it has somewhat to do with video cards I'll post it here
I have the full version of fraps and in Bad Company 2 whenever I hit the record button my frames drop to 30. I have tried settings the record rate to 50 and 60 in fraps, as well as settings up a custom setting for 90fps recording. Have tried in full size and half size with the same results. Does anyone know whats going on here, or is this normal?
BC2 Settings 1920x1080, All HIGH, HBAO ON, VSync OFF, 2xAA (Honestly dont see the difference going from 2xaa to 4/8/16 except for the fps drop so keep it at 2x), 16x AF. PC Specs are in my sig. I usually get between 80-100fps while gaming, depending on map and whats going on in the match.
All comments and/or suggestions are greatly appreciated.
Thanks!
Thanks!
