TL;DR - 3 monitors, 1 5770, 2 3850s (xfire or not) asrock z68 gen3 professional - will it work?
Hi all, So I am in the process of upgrading my entire system and I am (painfully) waiting for ivy bridge and the next gen GPUs to come out so I can grab a current gen card on the cheap.
That all being said, my current config has two sapphire 3850s in xfire running on a Q6600, I know, ancient and severely needing an upgrade. Well I'm trying to get a 5770 to hold me over but my big question is this, I have the Asrock z68 gen 3 professional which has 3 PCI-e slots, if and when I get my CPU (3770k hopeful) would I be able to run the 5770 in the first slot and the two 3850s in xfire in the 2,3 slots.
I am planning on having the 5770 standalone running my new 2560x1440 display (http://hardforum.com/showthread.php?p=1038457820#post1038457820) and the 3850's running a pair of ASUS VH242HL-P monitors.
My primary usage for this system is Photoshop but I also play WoW and SWTOR but thus far I only use my main screen for gaming. I will be running on windows 7 professional 64 bit, and power shouldn't be an issue for this setup - modular thermaltake 850watt - 2 6-pin + 2 6/8-pin PCI-e leads. If there is any more info needed for a good recommendation let me konw. Thanks!
Edit - Also if this is possible, and it is smarter to put the bigger display on the 3850s that would be good to know too. I figure I'm treating this system like just two mismatched cards but I don't know if I can really do that or not.
Wings
P.S. Also I realize this is a giant backwards way of doing this sort of upgrade, but I have had some unexpected expenses recently and I really need to keep costs down an my upgrade path on a piecemeal basis, so no comments like "just buy a brand new 7xxx GPU and all your problems will be solved", it would be great but not in the budget until summer at the earliest.
Wings
