sleepeeg3 said:Why in heck would you run without a heatsink?
Winflash.
275 would be the motherboard limiting you, not cpu.gemini8026 said:hi all, opteron 165 with 2 gigs pc4000 here on this mobo.
Processor has ltosa room, but im brick walled at 275. Im happy with the 2500mhz though, it's been stable and great, but anything higher, and she wont boot!
Good mobo though, im not disappointed, I would like to see this cpu's limit though!!!!
gemini8026 said:uhmm yah, I was posting saying I would like to know the CPU's limit without having the 275 limit of the mobo.
well that wouldn't be possible without either a) having another mobo that can hit higher fsb, or b) figure out how to "break" the cpu so that it unlocks the upwards multipliers like FX cpu's. if you can figure b) out, you'll be a godgemini8026 said:uhmm yah, I was posting saying I would like to know the CPU's limit without having the 275 limit of the mobo.
vibe said:I am about to buy this board after damaging my tforce 6100 this weekend.
Was wondering, since the 6150 is dual header, how does the foxconn do this?
I don't see a s-video connector, am I just overlooking it?
vibe said:I don't like their funky heatsink locks. From the images I take it there are no standard
push-pin holes to replace it with a copper heatsink/fan? You'd have to bolt a fan on top?
vibe said:I think the only downside on the foxconn over the biostar is no 1T support on ram
since they keep the onboard video active at all times. When I went to pcie video
on the biostar, the 1T was a nice boost to the ram.
vibe said:The dual voltage control on the vcore looks interesting. The voltage boost setting looks
like it is designed to support cool'n'quiet since the base setting can be left at default?
MicroATX boards, including the Foxy and Biostar, aren't very reliable OCers. Sure, they OC just fine...sometimes. It's really random. Perhaps you got a dud?MikeyB said:Hmmm.
I tried again with 3x HT, 8x multiplier, and 225 fsb. No go. Divider did not help either. I wonder if this is just a bum board.
PS:
What is the proper orientation for the enermax liberty in the qpack? It seems like it fits best with the fan pointing towards the top of the case, but this would cut off all air flow.
