Viper87227
- Jun 2, 2004
Sorry if this has been posted, I looked but couldnt find anything...
I have been having problems OCing my winchester on my Ultra-D. Its a CBBID 0450 so I didnt expect much, but I just about crapped myself when I maxed out at 2.3ghz. Even with 1.7v, I couldnt get 2.35 prime stable. 2.4 would give me errors and BSODing, and I coudlnt even boot past 2.4. This is all on water mind you, heat was definatly not the culprit. I was ready to throw in the towel, figuring my chip was just crap, when I found another post on XS with someone who had the same issue. To get my voltage I was running 1.55v VID, and then a VID Special % to get up to 1.7.Everything reported it as 1.7v, but it wasnt! Follow what the other guy had done, I dropped my VID to 1.4v, and raise my VID Special %. This time I was actually at 1.7v. I was prime stable up to 2.6ghz, but due to my BH5 hitting a wall at 250mhz, opposed to run a dividor I just run at 2.5ghz, 2-2-28, 1:1. Its still crappy results, because I shoudlnt need this much voltage to get this high, but it beats the crap out of 2.3ghz. So, if you are having problems with low overclocking, check to see how your VID is set up....you could have a bit more room to OC.
